Hi I've got a 2001 1.9 berlingo when I try to start the berlingo the heater light does not come on and it will not start can anyone help me with this please thanks phil
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
When you say it does not start does it mean the engine does not turn over, or it is turning over but does not fire?
The (heater) glow plugs are controlled by a relay which sits on the nearside inner bulkhead just behind the n/side headlight.
These sometimes gave problems with a bad earth. Check to see if the relay clicks when switching on ignition.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Given: 137
33
07-03-2018, 04:58 PM
(This post was last modified: 07-03-2018, 05:01 PM by brodfather11.)
Is there 12 volts at the glow plug terminals ?
when the ignition is switched on the plugs should come on for about twenty seconds or so the after it starts they stay on for about the same then go off. The voltage must be checked in that time window.
Threads: 43
Thanks Given: 137
33
You should check for 12 volts at the relay, if not the fuse no 22 (20 amp) in the engine fuse box feeds it
