Threads: 3
Thanks Given: 10
First of all back handle goes and cannot operate from outside and now side loading door handle just stops engaging to unlock.....there's a big , metal security screen separating cab from back of van area so cant open it at all of from inside...any ideas guys?...plus is this all an MOT fail as its due soon....feel pretty fed up atm.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
The back door handle rod was known for slipping when the handle was worked from the outside.
There was /is a simple little metal catch that allowed the operating rod to slip through it and it wouldn't operate the latch,
its an easy fix
if you can get into it to work from the inside
Don't know about your side doors
What about drilling hole through the metal bulkhead and poking the opening inner handle with a rod ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thanks Received: 4 in 4 posts
When you open the rear right door there’s a little rubber grommet near the latch, look in there with a torch you’ll see what’s happening. I managed to get a small nut, think it was 6mm in there & threaded it onto the rod, works a treat
Threads: 3
Thanks Given: 10
i think when i looked at the culprit it was a blue, plastic part that had snapped...no clue what it is or how to get replacement
Threads: 41
Thanks Given: 134
31
Threads: 3
Thanks Given: 10
can only open doors from the inside but can see how i can upgrade blue securing clip for the back door, havent had time for looking at the side door.
Threads: 3
Thanks Given: 10
well the blue securing like washer was snapped and the back handle rod just moved freely back and forth....managed to get a think cable tie through the needed area and pulled very tight....problem solved and now handle operates from the outside
