Light's
I have a problem with my light's and indicators which is whenever I put my indicators on my light's come on and my indicators turn off I have to wiggle the lever to get my indicators to work and to my light's off.
I own a 52 1.6 16v berlingo multispace forte, can anyone help me?
Sounds like the comms unit has worn - you can buy a small plastic plunger or just replace the whole comms unit. Have a look on ebay for both and take your pick.
There was a guy on the forum that repaired comms units but not seen him on here for a while. Have a look on ebay for comms unit repairs and see if he is still doing it.
(23-03-2018, 07:52 PM)Tomcat3 Wrote:  There was a guy on the forum that repaired comms units but not seen him on here for a while. Have a look on ebay for comms unit repairs and see if he is still doing it.
Do you have to send the comms unit because mine is still on the car.
(23-03-2018, 05:55 PM)polar Wrote:  Sounds like the comms unit has worn - you can buy a small plastic plunger or just replace the whole comms unit. Have a look on ebay for both and take your pick.
When you say a small plastic plunger what do you mean?
https://www.ebay.co.uk/itm/Citroen-DAV-F...#vi-ilComp
Thanks, but is it easy to replace?
Yes you remove the comms unit and send it to him. Its fairly easy to remove the only tricky bit is removing the airbag if you have one. It is covered in the manual or there is plenty on the forum about doing it.
You could have a word with these people they may be able to help http://www.bba-reman.com/gb/index.aspx
Ive never used them but a friend used them for an ecu repair and they fixed it.
  • Squad
Ive replaced the plunger myself - done a few of them. Its easy for me to say "its an easy job mate" but im a retired mechanic! So im not able to give you any realistic advise on how easy they are to replace - sorry.
I will tell you the job can be a bit hit and miss because some comms units have more faults than just the plunger - however from the symptoms you describe it does sound like the plunger only at fault.
  • Squad
(24-03-2018, 09:05 AM)polar Wrote:  Ive replaced the plunger myself - done a few of them. Its easy for me to say "its an easy job mate" but im a retired mechanic! So im not able to give you any realistic advise on how easy they are to replace - sorry.
I will see if I can get a mechanic to do it.
[-] The following 1 user says Thank You to Squad for this post:
  • polar
Last Post: xavier988
Today 10:23 AM
Today 10:21 AM
knocking from rear
Today 10:19 AM
footwell fan
Last Post: de62
Yesterday 10:13 PM
rear washer fires front?
Last Post: Brooky325
Yesterday 10:00 PM
Remote key fob window function?
Yesterday 05:58 PM
Halp, me van had died :(
Last Post: ae3
Yesterday 05:43 PM
Drop in fuel economy
Yesterday 09:38 AM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
Frequent DPF REGEN's
11-01-2025 08:59 AM
