25-03-2018, 10:31 PM
Hi. I have a 2009 Berlingo (New Shape) which decided to just not start one day recently. So after checking that the power was coming to the moter I decided it was the starter and swaped it out for another. Pain in the arse job I might add. Only to discover it was exactly the same.
So after some head scratching I figured it must be the starter relay and I figured that this should only be powered when the key is turned to the starting position only to discover there is about 8 or 9 volts in this circuit all the time.
Was wondering if anybody had any ideas here?? Kinda stuck as to what to do next??
Plus, what's the handiest way to check the starter moter and relay when taken off the van??
Thanks...
Thanks...
