Axle swap. Brake pipes change as well?
Hello... I'm swapping rear axles. Donor car had reconditioned one last year. Is it worth changing brake pipes and flexible hoses for new ones at the same time? Much of a job?.
I might have no choice, of course, depending on how well it all comes apart.
Wish me luck ?
You don't have to swap them, but if they're the originals, it may be a good idea as they can get brittle with age, and may not survive the transfer unscathed. Or possibly fail a short time later...
And yeah, the pipes is a pain in the ... to get done. Mostly because the nuts are probably fused solid by now. When I rebuilt my rear brakes I ended up cutting them off the brake cylinders, and replacing both cylinders(were leaking, so they had to go anyway) the first pipes, both flex hoses, and one segment all the way to the balancer thingy.
I assume the new axle comes with refurbished brakes, new hubs in place, and new shocks?
(Check if it's the right hubs for you. There's at least two variants for ABS and one version for non-ABS. The difference for ABS is the number of teeth)
You may need new rubber blocks at the rear end of the axle mounts. They can fail rather invisibly.
Best to renew the flexible hoses when performing major surgery you have perfect access.
Metal pipes - if they come apart ok then why change them, inspection will reveal all on dismantling.
I'm getting the axle done on my berlingo, my mechanic recommended changing them for the same reasons, and he said they cost naff all anyway so it's worth doing.
Sent from my Pixel 2 using Tapatalk
2006 Citroen Berlingo Enterprise 600D
420k+ on the clocks and still chugging away   Big Grin
Update:
Wish I'd replaced them all with new pipes when it was in bits.
Turned out the nsr brake wouldn't bleed up. After hours of getting nowhere, turned out there was a blockage. All good now.
(13-04-2018, 11:38 AM)ian432 Wrote:  Update:
Was it the flexible pipe that was blocked. They have been known for the inner walls to collapse.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Rear brake caliper piston problem
Yesterday 08:47 PM
Cruise control retrofit
Last Post: E30alex
12-02-2025 08:39 PM
Part ID, what's this for?
Last Post: Muppets on Mars
12-02-2025 12:19 PM
Alloy wheels
12-02-2025 08:05 AM
2011 B9 DPF warning light
11-02-2025 07:13 PM
» Replies: 15
Greetings from Romania
11-02-2025 10:43 AM
Whats Your Berlingo 'Pet' Name.
Last Post: Lokusan
09-02-2025 08:17 PM
» Replies: 32
Indicator/lights Stalk
09-02-2025 06:26 PM
Roof bars and roof box
Last Post: LukeClark
08-02-2025 07:24 PM
Remove Wing
Last Post: ADarkDividedGem
06-02-2025 02:13 PM
