notchy and heavy
i have an issue with my 06 600d, the steering is notchy and heavy, it will be heavy for 20degrees then be fine then heavy again etc
i suspected the powersteering pump so replaced with a refurb unit, and boom steering was fine for 200miles and now its starting to deteriorate again.
anyone had this before? fluid level is fine so i dont think im loosing any
cheers
   chris
Its not the U/J at the bottom of the steering column is it? Known for seizing and giving your symptoms
As Polar says check the U/j where it enters the engine bay, the heat of the engine dries it out and becomes stiff. Spray it with something like motorbike chain lube, also there is a U/j under the dash check that to.
cheers gents i will investigate tomorrow after work when the sun is out. is it possible to buy a new U/J or is it going to be a PITA to rectify
Yes you can just buy the U/J but like Tomcat says a decent spray can sometimes sort it.
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
