How often do you change your Oil
I'm driving a 2011 B9, 93000 miles on the clock
For me its every 6000 miles or 10000 Km, possibly i'm overdoing it ?
Sounds reasonable.
Hope you change your oil filter at the same time.
Gravity
Oil is cheaper than engines so I always change oil well below the recommended intervals.
For me it's every year, Mann filter and Citroen approved oil regardless of mileage, most years I'm probably well under 6000 miles as it's my wife's runaround.
Mark
Sent from my LIFETAB_S1034X using Tapatalk
Oil filter change for sure every time.
Service interval on mine is 16k - thats when the oil gets changed, near enough every 6 months anyway.
The van will have 80k on it come its first MOT so i will chop it in then so long as I like the new Bingo in the flesh
A by pass oil filter is the way to go if you want the best protection for your engine.
(12-04-2018, 05:52 PM)jj9 Wrote:  A by pass oil filter is the way to go if you want the best protection for your engine.
 As a secondary filter yes certainly ( my land rover engine ONLY has a bypass filter  Sad )
 I do my oil and filter twice a year, before the harshness of winter and then before the harshness of the summer sun.
From 6000K up to 16000K, quite a bit of variation there.
(13-04-2018, 04:19 PM)michaelg Wrote:  From 6000K up to 16000K, quite a bit of variation there.
Also, different specifications of oil will make a considerable difference. I suspect with my van being the last generation and extended service intervals - it’s oil is full synthetic low ash. I know it’s not cheap per litre!
Today 12:50 PM
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
