Threads: 7
Thanks Received: 210 in 121 posts
Thanks Given: 16
9
My M59 (presume the M49 is the same) has one main beam facing much too far right.
I can adjust it's beam up and down easily enough, but nowhere can I find an adjustment for side to side movement.
Any tips or ideas? I'm new to this model and still learning.
Gravity
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
I was wanting to adjust mine too, If you find out let us know
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 7
Thanks Given: 16
9
Well, I've now had a thorough inspection with a worklight, and can't see and side-to-side adjustment. If I have to, I will take the whole light out (bumper off jobbie I suspect) so that I'll know for the future.
Watch this space ... eventually.
Gravity
Threads: 6
Thanks Received: 4 in 4 posts
Thanks Given: 1
Are you sure the bulb is seated properly with retaining clips fully in place ?
