Driver's door open sensor switch
Hi all ,
My berlingo has doors that auto lock when I move off, my problem is 50 % of the time when I open the driver's door the other doors do not unlock as they should, if any other door is opened from the inside all the others unlock.
My guess is the driver's door open sensor switch isn't working all the time.
Can anyone offer any advice on if I'm on the right track , and how to tackle a repair at the moment I can't even find the location of the switch as I was expecting to find it in the door Piller.
Any advice would be most welcome.
Mark
Sent from my LIFETAB_S1034X using Tapatalk
I think in the newer models the switch is built into the door lock.
You can check the wires from the door to the pillar in case they are broken
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(17-04-2018, 04:30 PM)brodfather11 Wrote:  I think in the newer models the switch is built into the door lock.
Thanks, I will take a look.
Mark
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
