Threads: 8
Thanks Given: 2
Hi to all,
I`ve owned my Peugeot Outdoor 110hp for 3 years and covered about 32,000 miles.
I usually fill up to the brim every time and run the total tank down till the orange light comes on.
About 18 months ago I had the fuel additive reservoir changed or topped up at the main Peugeot dealer in Preston and it has been fine ... until my last 2 fill ups.
So now when I turn on the ignition and drive off I hear a buzzing sound at the rear. Switch off the ignition and this buzzing then stops. It sounds like a pump and the only thing I can think of is the fuel additive reservoir.
Anyone have an idea what it might be ?
Cheers Circlip
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
Sounds like your additive could have ran out.
Best to get the level checked physically . It obviously shouldnt have used used it all by now, but the pouch type do gave a habit of leaking, so maybe it’s all leaked away.
Threads: 7
Thanks Received: 27 in 25 posts
Would a main dealer refill a pouch thought they just wanted to sell a new pouch plus fitting no messing around as they dont like to get there hands dirty
Threads: 12
Thanks Given: 16
37
It will be the Elloys pouch, like I said, it may have been replaced, but they can easily split.
Very simple to have a look & see if it’s empty or leaking.
Threads: 2
Thanks Received: 15 in 15 posts
Thanks Given: 1
The first package should last for 100.000 to 120.000 km.
But small stones between the bag and holder could produce a leakage.
All the best Rolf
Regards Rolf
_______
Berlingo Blue HDI120 S&S Shine, 08/2016, KYANOS Blue Metallic
The following 1 user says Thank You to rolf50 for this post:1 user says Thank You to rolf50 for this post
• doofer
Threads: 28
Thanks Given: 78
Do not touch any leaking fluid as I believe it's dangerous.
Mark
Threads: 7
Thanks Received: 61 in 55 posts
Thanks Given: 16
04-05-2018, 05:04 AM
(This post was last modified: 04-05-2018, 05:07 AM by Luis Rosa.)
I read that the additive pump can make high frequency sounds, even when working normally - it is described somewhere when using diagbox software, and that you can change its action timing, so that it is more discrete, and not bothering you. The pump will engage every time you open the fuel filler cap and put fuel that varies the level in more than 1/4 to 1/2 a tank (or something like this), in order to add EOLYS to the new diesel (that is why you should always fuel from empty to full diesel tanks, because the pump will add the same amount of additive every time it is engaged, independently if you fueled 1/2 or a full tank). With diagbox you can set it to act as soon as the motor is again on, or you can set it to wait some time after that, so that the car is already rolling and the pump noise becomes less audible, masked by all the other noises from driving( I think this is your case)...So you may just have a very good ear for your pump´s frequency. I would still go for the confirmation of the additive tank/bag being undamaged/full of additive, but it may very well be that you just have a whining pump, and you have to live with it for 20 or 30 seconds every time you fuel your car.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
04-05-2018, 07:56 AM
(This post was last modified: 04-05-2018, 07:57 AM by Johny555.)
I wouldn't run the fuel tank to near empty,you need a least 1\4 tank for the regen to work,
