Threads: 123
Thanks Given: 250
34
Hi, I'm having ongoing issues with the steering. It seems fine when warm, but lumpy / stiff when the weather is cold. I changed the fluid to ECP ATF DX III, things improved for a while but then went back to as before. I changed the oil again and the same thing happened so I'm wondering if I need something different, maybe fully synth oil?
Any thoughts welcome.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
The Universal joints in the steering column nice and free?.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
I wonder if the pump pressure is on the low side or the oil is cavitating (filling with air bubbles for some reason)
Threads: 41
Thanks Given: 134
31
26-04-2018, 07:27 PM
(This post was last modified: 26-04-2018, 07:28 PM by brodfather11.)
I'm not so sure that different oil in the steering pump will make a noticeable difference, could be wrong again though.
What about the other steering joints , t/rod ends / lower suspension joints and top strut bearing, A sticking/tight t/rod end if really tight will give a jerky feeling . A broken coil spring can also give that feeling
Threads: 123
Thanks Given: 250
34
A timely reminder for me to give an update.
My steering is now fine, I think it was a mixture of that UJ at the bottom of the column & old oil which I flushed via repeated filling / turning to full lock on both sides them emptying via a suction bulb. The UJ took a lot of time to get properly free, I used some WD40 to free it up, then bike chain grease afterwards for proper lube. Even then it took a couple of days to fully return to normal.
