Threads: 43
Thanks Received: 2 in 2 posts
Thanks Given: 28
Hi,
does anyone know how to change the aerial on a 2002 Citroen berlingo multispace 16v 1.6 as I can't get any radio stations,
I hope that someone can help me.
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
if the interior lamp is the same as a van then the lamp pops out and the base of the aerial is just there. just unscrew the nut and it falls off. Take out the radio and unplug the old cable
Changing the cable is easy if you tie a bit of string to one end pull, off the plastic panels beside the windscreen and gently pull it out and tie the string to the new one, and gently pull it back the same way .
Behind the n/side (?) plastic panel is where the cable runs down
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Given: 28
Could it be the aerial that is why I can't get any radio stations?
Threads: 23
Thanks Given: 46
5
Have you had this car from new? Has this problem just started?
Threads: 43
Thanks Given: 137
33
If the second hand one a replacement/after market one (not a factory fitted one) , if so it doesn't need a vin for it to work
Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
Good luck changing the lead.. I just changed mine. You will need to get access to the roof lining above the windscreen and remove the trim on the left of the windscreen and the rear of the glovebox. The aerial lead is clipped behind the roof lining and down behind the left trim which are both pretty easy but behind the glove box the cable is cable tied to the dashboard.. I did mine because I had to take the dash out and change the heater matrix. The new lead I got from Citroen, it was only £9 all in which was cheaper than anywhere else I went.. I also fitted a new aeriel base as I had it apart.. I live near Newbury and I can now get BBC radio London !! over 40 miles away...
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 68
Thanks Given: 22
Threads: 68
Thanks Given: 22
