Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
You will need a fuel resistant O ring, you will probably find one on ebay if you know the size.
If you're not sure how to measure it just Google measuring an O ring.
Threads: 17
Thanks Received: 14 in 10 posts
Thanks Given: 6
I also have a fuel leak from the throttle spindle on the top of the pump.
Is there a simple fix ?
It only seems to leak at idle.
'98 D 800 van
Threads: 17
Thanks Given: 6
I also have a fuel leak from the throttle spindle on the top of the pump. (just above Lucas' red circle).
'98 D 800 van
Threads: 17
Thanks Given: 6
Just had mine fixed by Bennetts Workshop in St Albans, about £200 for new throttle spindle etc.
Not an uncommon problem apparently.
The Lucas fuel pumps are repairable (ie spares available), the Bosch type are not !
'98 D 800 van
