[Engine] Loud engine 1.9d, can't figure it out
Yesterday morning when I started up the van, I instantly noticed the engine was much noisier than normal, it was fine the day before. Its sounds almost like a bad exhaust leak and that's what I thought it was.
This afternoon Iv got under the van and checked the exhaust over and manifold, can't spot any issues visually and exhaust is in pretty good condition. I then started the van and blocked the tail pipe hoping I would find a hissing noise leading me to the leak, that didn't work, no hissing and the engine stalled after a few seconds.
The heavy engine noise seems to be coming from around the engine bay area, Iv checked the air box and inlet manifold, also checked for loss of oil pressure. Everything looks and seems normal, van drives fine as well. Its hard to trace exactly where the noise is coming from, seems more to the top left of the engine.
Can anyone think what could cause an exhaust blow throaty sort of noise?
2006 Berlingo 1.9D
Sent from my Pixel 2 using Tapatalk
2006 Citroen Berlingo Enterprise 600D
420k+ on the clocks and still chugging away   Big Grin
Have you got an injector leaking? Would be very unusual on a 1.9 though.
Check the airbox is not loose on it's mountings.
[-] The following 1 user says Thank You to Egg on Leggs for this post:
  • polar
Found it!!
Power steering pump has come loose from the engine block, its rattling around like mad, don't know how I missed it the first time I checked.. If I put my hand on the pump the noise goes away, I can't believe a loose component could cause so much noise lol
[-] The following 1 user says Thank You to dan.wfs for this post:
  • RolyG
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
