Gear 8 oil
Hiya all...
   I have 3 Berlingos, all 1.9D, 2x vans and one Multi.. I have changed the gearbox oil on them all and have been supplied Total gear 8, this is suppose to be the correct Citroen oil for a BE4 gearbox, so why is it that all three now have graunchy, grinding gear change ? The gear change is not smooth by any stretch of the imagination..
Has anyone else noticed a difference after an oil change ?
 What gearbox oil have you used ?
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
I changed my gearbox oil after a driveshaft came out while working on the strut. The gear change was noticeably smoother after. Like you, I used Total Gear 8 bought from GSF.
I use Total gear 8 oil and have no problem.
same here never had problems with it
Well I have bought some PSA recommended oil from Smith and Allen. EP 75w80 PLUS mineral. I have done 150 miles since and the gearbox is back to being easy again. The worry is that when I drained out the Gear8 is that there was a sheen of gold in it which tells me the gearbox has a very much shortened life.. I better start saving for a recon box...
 Does anyone know of a reliable gearbox reconditioners ?
The gold is just the oil - it is historical with gearboxes with bronze bushes in the gearboxes that if gold comes out the bushes are worn. That was very old school tech, dont worry your gearbox should be fine.
Haven't used it myself, but my Dad swears by using a 'gearbox oil treatment' on old gearbox's. (wynnes)  make a huge difference(so he says).
Guess its similar to the stuff they have for engines which quietens down old worn engines.
Maybe worth adding it in.
My Vehicles: 2015 Berlingo Enterprise Van 75 1.6Hdi
                   2015 Toyota Avensis Saloon 2.0L Luna
Sadly the gearbox has gone back to being a grindy, reluctant gear change.. A new gearbox I think...
Back pain / ache
Last Post: jw4821
Today 06:23 PM
Indicator/lights Stalk
Today 04:55 PM
2011 B9 DPF warning light
Last Post: IKUN
Today 04:51 PM
Yesterday 04:48 PM
Last Post: BrianS
Yesterday 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
Yesterday 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Last Post: pondweed
21-01-2025 01:21 PM
