  • 13 Vote(s) - 1.69 Average
COOLANT
Hi,
As this is my first Citroen and was serviced before I got it 9600 miles to next service, I was concerned that the coolant was clear. I am used to pink water or perhaps on a previous car blue but in the Berlingo it was clear. I did take a small sample and put it in the freezer with a similar sample of tap water and the coolant did NOT freeze. Is clear coolant normal for a Citroen?
Al
Normal coolant for modern (>2005) Citroens is BASF Glyssantin G33.
Before 2005 PSA used Revcogel 2000.
[-] The following 1 user says Thank You to pk7478 for this post:
  • ron
If it didn't freeze it must have coolant in there and putting it in the freezer is a harsher test than even our worst British winter.
Easy way to check is drop into your nearest kwik fit they do a ph test for free problem sorted as do many carparts outlets Smile
(15-11-2011, 09:49 PM)tucker Wrote:  If it didn't freeze it must have coolant in there and putting it in the freezer is a harsher test than even our worst British winter.
Why British winter is worst?
No, PK, I am saying that a fridge freezer is far colder than anything the British winter can throw at you. So, if it survives the freezer, it will have no problem surviving our english weather.
The coolant in mine is grey so would look clear in small quantities.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
