Threads: 2
I hope someone can come up with a solution for me.
I recently acquired this vehicle and did the following work.
Replaced: Reconditioned steering rack
New bottom wishbones
New off side drive shaft
New fluid in power steering pump and reservoir
New track rod ends
I drove to MOT station about 10 miles each way with no steering issues. The van passed.
I did a couple of short trips, no issues.
On a longer run after about 50 odd miles van started to drift from side to side, it became almost too heavy to pull back. Then the steering became lighter and I was able to correct it. Then it started to drift again. It is now undriveable.
I have checked the universal joint it was covered in grease. I can't find play anywhere. Tracking also done.
Any help would be appreciated.
Threads: 9
Thanks Given: 316
15
Could be a faulty steering rack?
Threads: 7
Thanks Received: 210 in 121 posts
Thanks Given: 16
9
With no real info other than a list of parts you've changed, the replies you get will be guesses based on each posters experience.
Here's my guess:
Old adage - Last thing changed is first thing suspect.
So to me, the most likely culprit seems to be a track rod end not fitted/tightened sufficiently, which has now worked itself loose. That would explain the steering symptoms you describe. But it could be any part of your work, so it's worth re-checking all your work first, just to satisfy yourself that everything is torqued up correctly. Costs nothing but time.
Gravity
Threads: 67
Thanks Given: 237
50
First thing I'd do would be with the vehicle static and engine running operate the steering repeatedly from lock to lock whilst checking for a complete and smooth motion of the wheels such as would normally be seen listening also for any unusual noises. It is possible the new rack is defective in some way.
A check on all steering and suspension components and associated fasteners would be next on my list.
Jacking the wheels up and manually pushing and pulling the wheels from lock to lock may reveal something, steering lock disabled of course.
With the wheels up perform the standard check for wheel bearing / track rod end wear this may reveal something.
Serieal Berlingo owner
Threads: 123
Thanks Given: 250
34
With both the front wheels off the ground, is the steering any easier? With / without the engine running?
Threads: 67
Thanks Given: 237
50
I don't see the top strut bearings seizing but you never know, drop a TRE and try rotating the strut by hand to see how they are - do both sides of the vehicle.
Beyond that I'd go to your local friendly garage and get them to check it over on the ramp before you go too deep as they may have some experience of this issue.
If all the above is good I'd put my money on the rack being defective.
