Crank ,no start, petrol 1.4
Hi all,
Having a strange problem.
2006, 1.4 petrol.
The other week went out in the morning and the engine would crank but not start. So I looked for spark, not easy with a coil pack, and no spark.
Spoke to mechanic friend, he said more likely fuel issue, and said the no spark can occur if computer doesn't see some parameters.
So I checked the 40 amp fuse in the engine fuse box( fuel pump), it looked fine.
But when put back it , it started fine.
All well for a week or so, then same thing, morning start, crank and not firing up. So I pulled out the fuse for the fuel pump, looked fine, returned it.
Started and ran.
Any ideas?
Steve
mabe corrosion in the fuse holder causing a resistance and voltage or ampage drop
(11-05-2018, 06:31 PM)polar Wrote:  mabe corrosion in the fuse holder causing a resistance and voltage or ampage drop
Entirely possible.
Any tips on cleaning, guessing sand paper is too aggressive?
Steve
Contact cleaner spray?
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
