Threads: 43
Thanks Received: 410 in 367 posts
Thanks Given: 137
31
What model , engine etc have you got ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 43
Thanks Given: 137
31
I cant identify your part , what I suggest you do is an online search for CATCAR.INFO . this will bring up different makes of vehicles. select Citroen and your model etc , its quite easy to find diagrams for your gear linkage and then that will let you know if your part is available seperatly
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
14-05-2018, 08:49 PM
(This post was last modified: 14-05-2018, 08:49 PM by jj9.)
As far as I can see it looks like the part is only available with the gear change control cables.
You can see it on the end of the cables...
https://i.ebayimg.com/images/g/-l0AAOSwp...-l1600.jpg
I think I would have a go at cobbling something up to grip the threads.
