Front pad replacement
Hi Guys,
What's your opinion, when replacing front pads and pushing the piston back should I release the pressure by cracking off the bleed nipple or not bother, I've never done a car/ bike with abs before.
The Haynes manual says I should yet I've yet to see a YouTube video where they do it including brake manufacturers training videos.
What do you think / do ?
Mark
I think its up to you as your choice, I've never made a habit of doing it but I have done it. If not done right there's a chance of introducing air into the system
  A lot of people think you should do it to avoid damaging the ABS system/ master cylinder.
  In operation there is fluid moving back and forward as the brakes are applied and released and that doesn't damage the system.
   Doing it will introduce a little fresher brake fluid into the piston cylinder but that's about all.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
If there's muck in your brake system, chances are that it's in your calipers. I think best practice is probably to bleed the excess fluid you get from pushing the pistons back in, rather than pushing the old fluid back through the system and into the reservoir. I did mine without bleeding, the pads were low but still within limits and quite a bit of fluid was displaced out of the top.
The new MOT rules have some mention of brake fluid contamination, so probably best to top up, rather than have old fluid pushed back up.
Ok ,I'll give it a go then.
Thanks for your input.
Mark
When you depress the brake pedal, a small amount of fluid moves down the brake pipes as the brake caliper piston expands. When you release the pedal, the fluid returns to its previous position.
When you force the piston back in the caliper while changing pads, you push much more fluid further up the pipe than normal. Doing this without opening the bleed valve is effectively moving far more fluid back into the master cylinder. If you have abs, the same applies.
That's why it is good practice to open the bleed valve while forcing the caliper piston in. Excess fluid is expelled via the bleed valve, and the fluid in the pipework above this valve does not move, so there is zero possibility of dirty fluid contaminating either the pipework, the abs unit or the master cylinder reservoir.
Remember that 'dirty fluid' does not just mean an accumulation of solid particles. Brake fluid nearest to the disc goes through greater heating and cooling cycles than any other part of the hydraulic system, so this fluid gets most tired and contaminated. Expelling it through the bleed valve gets rid of this tired fluid. Remember to check the master cylinder level afterwards.
Gravity
Thanks Gravity.
Mark
My 2014 VTR auto passed the MOT in May, but the main dealer said the front pads would need changing in about 3K miles.  Mileage is only about 37K and I'm wondering whether to get the brake fluid changed at the same time.
Any advice welcome.
If its never had a brake fluid change it would be worth getting it replaced at the same time as the brake pads. It is recommended to change fluid every two years.
  • rnamman
Today 09:32 PM
Today 05:46 PM
Today 05:17 PM
Potential Purchase!
Today 03:03 PM
Last Post: DannyWxM
Today 12:55 PM
Diagbox 7.57 download
Yesterday 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
