exhaust
just failed on blowing on middle of exhaust but on looking underneath its just a straight section with a connecting backbox at back...i gather cat is up in engine bay. My van is a 2.0 diesel hdi berlingo. My question is, what part do i replace or look at replacing....totally confused tbh.
Looks like there's just 2 parts to the standard exhaust system, the silencer box at the back and the main pipe with cat.
Looking on ebay, there might be some shorter sections without the cat.
https://www.ebay.co.uk/itm/Citroen-Berli...SwI7tZ151r
  • Hung2hi
(14-05-2018, 11:35 PM)Hung2hi Wrote:  ... My question is, what part do i replace or look at replacing....totally confused tbh.
Get someone to briefly hold a rag over the tailpipe while the engine is running as you look under the car, this may help you identify where the leak is.
Failing that ask the MOT station for clarification.
  • Hung2hi
looking underneath car i can see various straight pipes been cut out and welded replacements but no centre box in middle section.....totally confused to what part im going to need
So far as I can tell, there's no box in the middle.
https://www.catcar.info/citroen/?lang=en...I9PQ%3D%3D
The ebay link I posted before also shows just a straight pipe. But if you look through the ebay listings you can see complete sections. Between the 3 examples you should be able to work out what you need.
  • Hung2hi
Hung2hi,
what year is the van?
Doesn't look like there is a middle box.
https://api.split.bosal.accounts.intract...S00848.png
The centre pipe with the cat is all one piece, the rear of which slopes upwards and this part tends to rot away beside where it joins to the back box, when this happens you either have to replace the whole centre pipe that contains the CAT (expensive) or get a standard centre pipe with the same sloping end and cut it off and weld it to your pipe.
Probably worth visiting an exhaust place and see if they can advise you.
  • Hung2hi
looks like a few parts have been cut out and replaced...no cat is there atm. Where the cat is meant to be theres the corrosion....its a 2005 model
And it didn't fail on missing cat?
Phew!
Gravity
well the tester put down he couldn't do emmisions due to corrosion, so might of picked up on absence of cat then.
Sounds like you're going to have to replace the centre section of the exhaust.
  • Hung2hi
Today 09:56 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
