engine mount
been told that my engine mount on my 2.0 berlingo van HDI has gone on its pre-mot  and making loads of noise while driving so stopped atm.
Looking at what kind of mount it is so i can buy and is it an easy fix guys? Its on the drivers side, and cant seem to find out which one it is
https://www.catcar.info/citroen/?lang=en&l=
You'll be able to look up the mount for your vehicle at the site in the link, or take a look on ebay.
  • Hung2hi
(15-05-2018, 08:46 AM)jj9 Wrote:  https://www.catcar.info/citroen/?lang=en&l=
best to buy one for other side also?
I would just do the one that needs done first, then take it from there.
  • Hung2hi
seen the bracket with rubber stops either side needs replacing....one side has snapped off, put a rubber door wedge down there to see if that solved the knocking and it did, so time to order that part. Least thats not too expensive
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
