Cruise control
Hi,
Can anyone tell me if 2002 Citroen berlingo multispace 1.6 16v ever had cruise control?
Probably not. But once my CC cluster arrives later today I'll be able to tell you if the retrofit works!
Right! Cruise CAN be retrofited to the 1.6 16v petrol BUT...
Where all the oil burner lot say you can only run the 'cruise no limiter' stalk, I suspect the petrol can run the limiter one. In my engine ECU options I can only set the 'cruise with limiter 'cruise option, the 'cruise no limiter' option can only be absent.
I haven't got a limiter stalk yet, but they are cheap so I'm getting one. I've got my cruise working with the correct milage on the dash so I'm happy for now!!
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
Yesterday 10:07 PM
Engine Fan Running
Yesterday 09:59 PM
Bettery Issues - A Solution.
Yesterday 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
