[Brakes] Disc pads.
Hi everyone, I have just changed the front pads and discs on my 2007 16v Berlingo.It all went well after following the posts on the Forum. But when I went for a test drive there was a scraping noise when I applied the brakes. I think the noise seemed worse on the nearside although I could be wrong. Please help!
Hi dunc 391 have you rechecked your work to maker sure you have done everything right?
Is it just the pads bedding in to worn discs?
Hi, thank you for your reply. I have fitted new discs and pads. I have only driven a couple of miles, do you think they may bed in, in time. The car stops well and doesnt pull to one side.
First, double check that everything is tight and there's nothing between the discs & pads, check the wheels turn freely when off the ground with no brakes applied. The discs and pads will take some time to bed in though, so if the noise is only when you apply the brakes a few more miles might be in order.
  • dunc391
(22-05-2018, 10:56 PM)dunc391 Wrote:  Hi, thank you for your reply. I have fitted new discs and pads. I have only driven a couple of miles, do you think they may bed in, in time. The car stops well and doesnt  pull to one side.
If you have checked your work over to make sure you have done nothing daft i suspect they are just bedding in and that is the noise you can hear.
did you clean the wax off the discs with brake wash?
I will double check everything this morning. Yes I did clean the new discs with brake cleaner.Thank you.
Well what an IDIOT. Stripped the caliper this morning only to find I had put a pad in the wrong way!! I had only done a couple of miles, so no real damage done. Thanks for all your help. Dunc.
Such is life sometimes! Good to know it was a simple fix.
  • dunc391
O dear - check check and check again especially when doing something you dont do very often or have never done before.
Glad you got it sorted quickly!!!!!!!!!!!
  • dunc391
Big of you to admit it and good that you didn't just hope it would "bed in" Big Grin
  • dunc391
Cold Starting
Last Post: jboy012000
Today 10:46 AM
M59 1.4 Petrol question
Yesterday 08:47 AM
Yesterday 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
