Heater control panel
Has anyone had this before?
Switching the fan speed from level 4 to level 3 there was quiet a lot of resistance until it finally gave in and went. Now the fan does`nt work on 4 and is full wack on level 3,2,1 and 0.
The switch still doesnt feel right, as if something inside is snapped/slipped. Had a look on ebay at the back of some used units and it looks like a sealed unit, apart from the heat control (left) and the output selector (right).
Ive already changed the Resistor a few months ago to a new item so cant be that.
Any experience with this please reply....
Cheers
(24-05-2018, 02:24 PM)peteh80 Wrote:  ... Switching the fan speed from level 4 to level 3 there was quiet a lot of resistance until it finally gave in and went. Now the fan does`nt work on 4 and is full wack on level 3,2,1 and 0.
You've obviously zeroed in on the cause of your problem - the switch.
Why not ask your Cit dealer for a replacement price?
At least that will give you a base line to work from if you then choose some other supplier.
Gravity
looking like an ebay replacement, theyre £45 on there so i bet you Citroen will want £350!
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
