Threads: 123
Thanks Given: 250
34
Interesting.
I don't know much about these engines, so am just guessing that the TPS will affect the injection timing, and maybe the fuel metering. Would be good to know how you get on with this.
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
05-06-2018, 01:44 AM
(This post was last modified: 05-06-2018, 01:49 AM by Sol.)
Is your engine braking a bit fierce with it like this? Could be idle / WOT control, though 3 wires could be either a potentiometer, or a change over switch. If it was a genuine TPS then I'd think it wouldn't like it held at full throttle position but if it's to detect whether your either pushing the pedal, or idling / coasting in gear with your foot off,, it could be an electronic throttle damper input to the pump to prevent the engine braking from feeling so strong (as diesels tend to do without damping), softening the response to a suddenly shut throttle while in gear, if you get my drift.
Older diesel's used to have a wee hydraulic damper thing on the throttle actuator to stop the pump's fuel control from slamming shut instantly when you lifted off in gear. Without it, you felt like you'd stood on the brakes when decelerating.
Threads: 25
Thanks Received: 47 in 29 posts
Thanks Given: 23
I have checked it with an ohm meter and is definitely a potentiometer. I have to say the transformation in driving the van is amazing it is like it is on steroids before it was like a slug now it flies I was even looking for an extra gear on the motorway. The jury is still out on the fuel consumption as it is so expensive at the moment it is hard to tell. I will keep you updated as I may try a pull up resistor across the wires so that when it goes open circuit it fails to the high voltage rather then low .
Threads: 75
Thanks Given: 223
164
Must be injection stroke (injected volume) control for the pump then, Bosch units on vw vans had a similar system using a variable voltage from a moving plunger and it was common on caddy TDI's to put a switch on this, simulating full stroke and generating a lot of extra power. (A bodge btw)
The only cautionary thing I'd say then, is exhaust gas temperatures (EGT) will go a lot higher than normal with increased fuelling on diesels, and you may not see any immediate issues from this, but its generally avoided by the tuning tribe for various reasons. Have a Google on that subject and make your own mind up.
Threads: 25
Thanks Given: 23
an update I have been running with the cable tie fitted since the post I have had no problems but I do drive conservatively, I have covered 11000 miles in the last year. Interestingly when I had the mot recently the emissions where one of the lowest he had seen. I get between 40 - 45 MPG. When I cable tied it originally it was just to try and prove that the TPS was faulty but with the increase in power and parts not being available it remained fitted.
The following 1 user says Thank You to jimbo for this post:1 user says Thank You to jimbo for this post
• cancunia
Threads: 3
I've done the same thing today and does seem to drive better however it has put my engine management light on, is that to be expected?
Will probably try to get a used one at some point but will run like this for now.
Threads: 3
It's a strange one as it's still plugged in so I guess it shouldn't put the management light on. Perhaps I ha e a dodgy wire to it and by taking it off I've disturbed that.
