Threads: 6
Thanks Given: 4
First off I ain’t now mechanic so can’t explain or understand mechanics very well, can anyone explain how the fuel filter is important in my van? I put it in for service and I got a phone call from the garage saying he has had trouble with the changing of the filter and something snapped, he priced the replacement and it was £80 odd quid so instead of paying that he welded it shut, he said it’s ok because the thing that snapped was a sensor that isn’t connected anyway and as I get my van serviced every year religiously it won’t cause any problems whatsoever.
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
Wish i knew what he was talking about but if you trust this guy then go with what he is saying - sounds like he is trying to save you money? I would go down and ask him to show you what he has done.
Threads: 2
Thanks Received: 9 in 7 posts
Thanks Given: 3
From memory, I think there may be a small heater unit that clips onto the fuel filter, which needs to be transferred from the old filter to the new one during a change. I wonder if was something to do with this? If so any problem may not become apparent until cold weather returns.
Colin
The following 1 user says Thank You to reedx for this post:1 user says Thank You to reedx for this post
• Madhouse
Threads: 7
Thanks Received: 8 in 8 posts
the only thing i can think of is.......it may be the water in diesel sensor..[try youtude].........they are not fitted as standard.....[ plastic type filter]....otherwise it may be a bracket holding the filter on, which as broken.......[there are two types of fuel filter.. metal can and a plastic] metal can type on left of engine. plastic type on right of engine...depending year and type of engine..
Threads: 9
Thanks Given: 316
15
With the quality of diesel fuel these days your rarely get water in the diesel filter if ever - i wouldn't worry about it just keep up with your normal fuel filter changes.
• Madhouse
Threads: 9
Thanks Received: 14 in 8 posts
Thanks Given: 1
Testing
Please ignore me...
Threads: 9
Thanks Given: 1
Can anyone tell me where the priming mechanism is on my 2017 bluehdi ?
I’ve looked everywhere - not going to take the filter apart until I know how to get it running afterwards!
