[Transmission] What gearbox sump washer/plug
Threads: 61
Thanks Given: 234
29
Hi All,
I was thinking of replacing my gearbox oil (M59 2007, 1.6HDi, manual 5-gears), but not entirely sure what size the gearbox sump washer is. I assume I cannot reuse it.
As useful as the servicebox may be, they have only listed the plug, no info on the washer itself (N 13 in the pdf). Reading here: http://www.aussiefrogs.com/forum/peugeot...-seal.html, it seems that the washer is 16mm copper crush washer. Is this correct?
Many thanks for any help.
Cheers,
saskak
(M59) - M59F 2 22D25A - ENGINE CLUTCH HOUSING MANUAL GEARBOX copy.pdf (Size: 169.53 KB / Downloads: 21)
Threads: 67
Thanks Given: 237
50
Just reuse the old one.
Serieal Berlingo owner
• jj9
Threads: 61
Thanks Given: 234
29
(02-06-2018, 03:43 PM)geoff Wrote: Just reuse the old one.
Well, yes, if a 16mm copper washer does not fit I'll reuse the old one. I was just wondering if someone knew exactly.
Thanks Given: 188
23
Yes it is a 16mm copper washer did mine the other week.
Are we there yet?????
• saskak
Threads: 61
Thanks Given: 234
29
(02-06-2018, 08:20 PM)Tomcat3 Wrote: Yes it is a 16mm copper washer did mine the other week.
That is great and thank you Tomcat3. Didi you reuse the filler plug washer, it looks like a 21mm.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
I'd go with geoff on this one.....just use the old one, like they do all of the time in garages!
I've had the same sump plug washer on since I got the car
Threads: 61
Thanks Given: 234
29
02-06-2018, 11:43 PM
(This post was last modified: 02-06-2018, 11:44 PM by saskak.)
(02-06-2018, 11:18 PM)jj9 Wrote: I'd go with geoff on this one.....just use the old one, like they do all of the time in garages!
They always used to charge me on the sheet for a sump washer though.
Threads: 8
Thanks Given: 305
37
Yeah but I bet you never got a new one every time.
The washers used to come in the box with some oil filters.
Threads: 61
Thanks Given: 234
29
26-05-2019, 11:19 AM
(This post was last modified: 26-05-2019, 11:23 AM by saskak.)
Just in case anyone is interested in the exact measurements of the bolts/washers for the gearbox.
The gearbox sump washer is copper 22mm OD, 16mm ID, 1mm thickness, but works with a copper compression washer 2mm thick. The bolt is 21mm socket.
The filler washer is aluminium washer, 22mm OD, 14mm ID, 1mm thickness, but works with 2mm washer. The bolt is 19mm socket.
No leakage with a torque setting for both bolts of ~22Nm. Mine took (from the filler) just under 1.9L of oil (Total Transmission Gear 8 75W80).
Cheers,
Saskak
Threads: 61
Thanks Given: 234
29
In case anyone is interested in changing the gearbox oil on the M59, here is a video of my attempt at doing it:
https://www.youtube.com/watch?v=95QarTgx4mI
In hindsight, I would probably use the top of the gearbox to fill it up (~1.9L). The 75W80 is really thick and even with heat, still very difficult to push inside the gearbox with a syringe. I have seen other bottles with some sort of a hose out of the cap that one can turn around and squeeze, but unfortunately the Total is a simple bottle.
Cheers,
Saskak
The following 1 user says Thank You to saskak for this post:1 user says Thank You to saskak for this post
• Hardnut
Last Post: BigVtwin996
Today 08:25 PM
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
