Threads: 44
Thanks Received: 11 in 10 posts
Thanks Given: 19
03-06-2018, 10:03 AM
(This post was last modified: 03-06-2018, 10:05 AM by lakeside.)
Help needed; is there a formula to assess the length of sliders required. I have made a sliding table extension but just copied a similar set up in a wardrobe drawer. I fancy making a drawer for my stove with ball bearing hinges but need to know how to assess the length of slider required.
Threads: 48
Thanks Given: 4
20
a general rule is to check the difference between 'collapsed' and 'fully extended' length of the rails. This needs to be the same length as you want the drawer to move out.
If you don't want the shelf to extend all the way out, you move the rails in as far as you want.
Noe that unless you get some 'triple action' rails, they will be longer than the depth of the shelf when collapsed.
Push-to-open types can be tempting, but unless you have extra locks, I expect that they'll 'jump the lock' if you hit a pothole.
(I'm considering a conversion of my 1999 berlingo, so are studying parts)
