Threads: 6
Thanks Received: 1 in 1 posts
Just a quickie, what brand cambelt kit do you buy?
Where do you buy it from?
Roughly how much do you pay - or expect to pay for it?
Just bought the shed on Sunday, don't know it's past so wanna start afresh,
at least I'll know when it was serviced last - always a good place to start.
George
If it ain't broke, don't 'fix' it.
Threads: 22
Thanks Received: 13 in 11 posts
Thanks Given: 24
Hi Oletimer,
I've just replaced mine, I bought the Gates kit which includes idlers, tensioner & water pump, cost was £64.95 - - ebay,
depending what engine you have, mine is a 1.9 diesel, I'd also recommend changing the aux belt at the same time, my one shredded & caused the cambelt problem, again from ebay aux belt, idlers & tensioner by Gates £64.71
Mk1, 1.9D, Admiral Blue, 51 Plate.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
I agree with THE BADGE, buy the kit on ebay, you often find the best deals on there these days.
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
Hi - as above, Gates kit (pump, crankshaft pulley bolt etc etc), splashed out on locking pins this time - mine is the 1.6 HDi so single cam and an easy job (made one Frankentool to get [16mm??] engine mount bolts off by cutting down a 16mm socket until it was about 10mm deep).
Best price - shop around - Eurocarparts/Carparts4Less or ebay usually but sometime Amazon can be fruitful especially if you have the correct part number
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
Threads: 67
Thanks Given: 237
50
I buy Gates for the whole kit, even comes with instructions.
Serieal Berlingo owner
