Threads: 2
Thanks Given: 7
does anyone know the part number for rear left/nearside wheel sensor cable.also looking for a fuse layout as cant get console power points to work.the vans a berlingo 600d 2007.any help appreciated .thanks
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
Try putting your VIN number in at the site in the link below and you will be able to look up the parts that should be fitted to your van.
https://www.catcar.info/citroen/?lang=en&l=
• scooby9858
Threads: 2
Thanks Given: 7
thanks jj9 already tried that through reading through the forum.on catcar for the rear left side there is 3 options on what abs unit you have 8.0 8.1 or 5.3 looking at the pic of the units it looks like 8.0 or 8.1 which is cable 4545c9.when searching for wheel sensor 4545c9 most say this is not compatable with your vehicle.the van is out of mot and the ABS light is on and on diagnostics it says its the rear left sensor.through looking for the ABS fuse the console power sockets no longer work i think a fuse has been put back in the wrong place.its turning in to a bit of a nightmare and thats before i take it for a mot.anyone know if i can take the van for a mot with ABS light on just so i know what else it fails on.thanks
Threads: 3
Thanks Received: 7 in 7 posts
Thanks Given: 3
Any warning lights on the dashboard are now a MOT fail, just encountered this on Friday fyi
Threads: 2
Thanks Given: 7
a wee update the vans been up for a mot and all the work is done except the only thing left to do is the ABS light is still on. when i bought the van 6 months ago the ABS light was on and dont know what the previous owner has done. does anyone know what fuse number it is and if the fuse is faulty/removed would that cause the light to come on.as i said above i had it on a diagnostics and it came up with rear left sensor but changed that and still the same thanks
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
01-07-2018, 09:16 PM
(This post was last modified: 01-07-2018, 09:20 PM by Sol.)
Engine compartment fuse box
Citroen Berlingo First – fuse box – engine compartment.
Fuse 3, 10 Amp is apparently the ABS control unit. Found this online, not sure how accurate it is.
• scooby9858
Threads: 2
Thanks Given: 7
thanks zion will have a look tomorrow.
Threads: 2
Thanks Given: 7
just had the diagnostics done again and its still showing n/s rear sensor and the guy thinks its the part within the hub either magnetic or reluctor air gap that needs cleaned or replaced.
anyone know what types in there and what size of socket to get the hub nut off.at least everything else ABS including the fuse seems to be ok.thanks again
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
(03-07-2018, 01:49 PM)scooby9858 Wrote: just had the diagnostics done again and its still showing n/s rear sensor and the guy thinks its the part within the hub either magnetic or reluctor air gap that needs cleaned or replaced.
Pretty sure the hub nuts are 35mm all round
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
The following 1 user says Thank You to GraemeT for this post:1 user says Thank You to GraemeT for this post
• scooby9858
