Central locking query
Hi guys
Wondering if you can help, I purchased a 2008 berlingo van which had the buttons missing from the remote for a considerable time.
I have since got the key repaired and have paired it however!
When I leave the vehicle for 5-10 minutes it does not lock or unlock but the instant I put the key in the driver's door and turn it I can then remove the key and lock and unlock galore.
Any ideas Smile ?
Thanks in advance
I wonder if the battery in the key is making a bad connection and the twisting action when you put the key in the lock and twist it is flexing the key just enough for the battery to make a connection again.
2008 model?
If it has the delaying feature built in, where if you unlock with the remote and don't open any doors for over a minute it will automatically re-lock. I suppose your unusual problem may be connected in some way to this, but I'm not technical enough to see the cure.
Strange one you've got there. Hope you get it sorted.
Gravity
As a bit of an update in hope that it may jog someone's memory.
It appears as if the van is forgetting the key, as when I go out of range of it, I need to unlock the van before the key becomes active again.
Any ideas
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
