Service light and other strange things happen
I bough the van and started using it in April, I reset the service count down at the time... Why then has it started to count down from 10k all over again ? I was keeping a mental note of mileage and was expecting it to be around 6k but when I looked it was reading 10k, it is counting down as normal so it has at some point reset itself, so I now have no idea where the count down should be.. I know the mileage as I go along because I write it on the fuel receipt..
  Something else I have noticed only the last few weeks is that the doors lock themselves randomly, sometimes the doors lock after a couple of minutes and sometimes I will be driving and the doors lock themselves or sometimes the doors don't lock at all..
 The Van is Haunted...
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Maybe worth checking if you have dirty water getting into the bsi module / ECU in the engine bay.
That would cause this weird behaviour.
Conductive fluid on the board or input terminals can trigger events as if you had pushed a button somewhere. Worth investigating before it gets worse. At least you can dry it out with a hair dryer and then seal where it's been getting in with clear silicone.
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
