Camper plywood thickness
Lightbulb
Hi!
I'm currently designing a amdro like conversion but am getting a bit caught up in the dimensions because of undecided thickness!
Planning on using plywood between 12-18mm but wondered if anyone had any advice on best thickness of ply? Smile
Thanks!
Read my camper build thread:
https://www.berlingoforum.com/thread-16358.html
It's all there with pics, including bed (single or double) dimensions for a B9 model.
I used 9mm ply for most of the construction, with 12mm ply on the bed base. This gave good rigidity without being too weighty.
Hope that helps.
Gravity
[-] The following 1 user says Thank You to Gravity for this post:
  • Little boy blue
Thank you for your thread Gravity Smile Did you use hardwood or softwood plywood?
Mileage
Yesterday 04:33 PM
eolys
Last Post: magoo1
19-05-2026 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
