Threads: 44
Thanks Received: 11 in 10 posts
Thanks Given: 19
17-06-2018, 10:19 AM
(This post was last modified: 17-06-2018, 10:20 AM by lakeside.)
I have lost the left rear door trim where can I get one at reasonable price, not sure if how many clips went with it.
Threads: 44
Thanks Given: 19
This happened near my friends house a distance away but the strip has been recovered also recovered a couple of clips but we think I will need some more trim clips and there seems to be two sizes needed;could anyone advise on that subject. the car is a 13 Reg Berlingo Multispace.
Might be sensible to go my dealer rather than get them on the internet but don't want to be charged silly money for a simple job.
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
Stick them on with the old clips and Sikaflex they will never fall off again. We stuck the door trims back on my friends Transit and held them on with masking tape till the Sikaflex set, just make sure they are clean and the area they are sticking to is sound and clean as well.
Threads: 29
Thanks Given: 67
20
(19-06-2018, 11:36 AM)photosavage Wrote: (19-06-2018, 07:32 AM)ffrenchie Wrote: Stick them on with the old clips and Sikaflex they will never fall off again. We stuck the door trims back on my friends Transit and held them on with masking tape till the Sikaflex set, just make sure they are clean and the area they are sticking to is sound and clean as well.
what Sikaflex did you use mate?
Just standard stuff from the local spares shop 252 or something like that, if you want cheaper try Tiger Seal or look for any PU adhesive online they are all pretty similar.
Threads: 44
Thanks Given: 19
thanks of the info.I hadn't heard of Sikaflex, looks good stuff. I had thought of a bit of glue assistance-as once it has been off- it might come off again.
