Threads: 3
Thanks Received: 2 in 1 posts
Thanks Given: 2
Hi all,
My son's 2002 1.9D multispace has developed a fault on the interior light.
Works fine from the drivers side but not from the passenger side.
Had a look but can't see any door switches. Please let me know where the switch is. Looked through the forums but didn't find the answer.
Thanks.
Pappy
Threads: 32
Thanks Given: 18
Is it a MK1 Berlingo?
Threads: 147
Thanks Given: 263
11
I might be confusing my vehicles here, but isn't there like a small plastic 'nipple' inside the door frame? Near to the door speaker region.
Threads: 32
Thanks Given: 18
Should be a little black rubber 'protrusion' just under the door check strap.
The switches do fail.
Threads: 32
Thanks Given: 18
Threads: 3
Thanks Given: 2
Thanks for the pic Steve - I'm sure we don't have that on ours. I have replaced door switches on other vehicles (VW) and was looking for a switch similar to this but I will look again when the car is back ( It's a 2002 MK1 Berlingo Multispace - but I'm sure Multispace and van will be the same)
Will keep you posted.
Regards,
Tony
Threads: 41
Thanks Given: 82
6
The courtesy light switches are an integral part of the door lock assembly, according to haynes.
Threads: 17
Thanks Received: 14 in 10 posts
Thanks Given: 6
My '98 has the rubber button by the check strap.
And it works sometimes and not others.
'98 D 800 van
The following 1 user says Thank You to colinh for this post:1 user says Thank You to colinh for this post
• Pappy
