Leak on power steering
Hi ive noticed a leak on power steering , it seems to be the bottom pipe on the steering pinion valve that goes onto the rack , it looks like its weeping out of the treads . Ive tried to tighten it but its very awkward to get on the nut , if it doesnt tighten will it be the pipe nut thats at fault of the threads on the pinion valve which would need replacing ? Many thanks for your time
Attached Files Thumbnail(s)
(29-06-2018, 09:07 AM)davidoneman Wrote:  Hi ive noticed a leak on power steering , it seems to be the bottom pipe on the steering pinion valve that goes onto the rack , it looks like its weeping out of the treads . Ive tried to tighten it but its very awkward to get on the nut , if it doesnt tighten will it be the pipe nut thats at fault of the threads on the pinion valve which would need replacing ? Many thanks for your time
Sorry can't offer much advice, but maybe clean it off with brake cleaner and then check it in a couple of days to see if you can deffo confirm the culprit. Also it may help to get a cheap brake pipe spanner and bend it to suit in a vice. Lastly deffo don't use an open end of a normal spanner as this is just asking to round them off.
Hope this helps
Mines been leaking in the exact same spot for almost 2 years now, never got any worse, I just keep topping up the fluid every 3-4 weeks haha
2006 Citroen Berlingo Enterprise 600D
420k+ on the clocks and still chugging away   Big Grin
Hi, I had an old berlingo that leaked like a politician in a coalition.
I used a bottle of repair stuff from ebay and it worked a treat (over 12 months then I got rid of the vehicle).
Can't remember the name unfortunately,
One thing after another
Yesterday 05:02 PM
Yesterday 10:41 AM
» Replies: 16
Yesterday 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
