Threads: 4
Thanks Received: 1 in 1 posts
Hi I have a 2011 berlingo 1.6hdi. The past week I've been getting an intermittent sort of pulsing when I brake and the past few days the abs light and warning tone has been coming on intermittent also. Any ideas? Would it be worth cleaning the senor. Cheers
Threads: 11
Thanks Received: 14 in 9 posts
Thanks Given: 5
I've had this before - there are a few threads on ABS if you have a look. Best to use a code reader if you can to identify which wheel. Then have a good look at and a clean up of the connector where the sensor plugs into the vehicle harness. A good proportion of my problems have been related to bad connections.
Threads: 4
Hi ok thanks for the reply. I'll try and get it on a code reader and see where to start. Cheers
Threads: 11
Thanks Given: 5
Just a quick note - I'm betting the problem is a front wheel. If you can't get to a code reader which reads the abs system, you could always clean up both front connectors. They're easy to get to, tucked behind a section of the inner plasic wing.
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
A pulsating pedal is often caused by an interruption of the signal from the sensor.
As said, the front ones are prone to picking up debris as they are exposed to the elements.
A common issue is the driveshaft gaiter clip breaking and the clip spins around randomly with grease coming out all over the place. Very easy for the signal to get interrupted.
Just turn your wheel on lock & take a look , you will usually spot this problem easily.
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
Or if it has abs rings on the driveshafts the ring has a layer of rust under it which expands and cracks the ring, the pulsing you feel is the wider gap at this point where it’s cracked as it thinks for a split second the wheel has locked
Ive also known rears on the likes of 307’s have a similar fault code mentioning coherence for a rear wheel on planet and lexia
Basically it can’t read one wheel speed correctly as it compares all four and steering angle to determine if the wheel speeds are correct
The following 1 user says Thank You to dumdum for this post:1 user says Thank You to dumdum for this post
• Art b
Threads: 67
Thanks Given: 238
50
Start by checking for worn discs / pads .... could simply be that, I had it a while back.
Serieal Berlingo owner
