Threads: 22
Thanks Received: 13 in 11 posts
Thanks Given: 24
Hi Folks,
I've just fitted a new cambelt to my 1.9 diesel DW8 engine,
good news is it runs, but it's rather noisy - knocking noise, I locked the Flywheel, Camshaft & Injector Pump & made sure all slack was taken up, I had the Cam & Injector Pump sprockets rotated clockwise as explained in the Haynes manual, something's not quite right, should I take the belt off & start again, or would moving the Injector Pump through its elongated slots make any difference ?
Mk1, 1.9D, Admiral Blue, 51 Plate.
Threads: 22
Thanks Given: 24
I need POLAR to answer this.
Threads: 65
Thanks Received: 715 in 612 posts
Thanks Given: 223
50
Start again definitely !
Check and double check / read and re read .... don't assume / make assumptions.
Did it knock before ?
Serieal Berlingo owner
Threads: 22
Thanks Given: 24
Didn't knock before,
was a very smooth motor, the auxillary belt shredded & worked it's way into cambelt,
hence the replacement.
I will take off & try again tomorrow, probably one tooth out on the timing.
Thanks for your reply.
Threads: 65
Thanks Given: 223
50
Good luck with it hope it comes good.
At least the 1.9 is a straightforward engine to do a belt on and you'll have all the tools to hand.
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
Hi sorry im late with my reply badge but been rough as you get the picture.
geoff has already said what i would have said.
Threads: 22
Thanks Given: 24
No worries mate,
hope you're feeling better soon.
The following 1 user says Thank You to THE BADGE for this post:1 user says Thank You to THE BADGE for this post
• polar
Threads: 22
Thanks Given: 24
When I changed the belt I couldn't find the timing mark on the pump body, so I scribed a line into the hub & pump body,
now I'm thinking this could be wrong - had the old belt jumped a tooth or more ?
The timing mark/hole for the Camshaft is about a 2 o'clock position, but I'm damned if I can find the one for the injector pump, any help is a lot of help.
Threads: 8
Thanks Received: 497 in 446 posts
Thanks Given: 301
31
The locking pin for the injection pump looks to be around the 1 o'clock position in the diagrams I've seen.
Some diagrams in post # 2 in the link below...
https://www.berlingoforum.com/thread-3245.html
• THE BADGE
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
Hi - double check the tensioner on the cambelt. I had a similar sound experience on an 8 valve Escort after replacing the cambelt - turns out I had failed to correctly tighten the belt tensioner and the tension pulley mechanism was moving about under the cover (how the belt never skipped a couple of teeth I'll never know).
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
