[Engine] code 0299, 09 berlingo 75 bhp
Hi there I’ve lost bottom end power very sluggish, when you keep the revs up she runs fine, plugged in scanner code 0299 comes up , the turbo seems fine no play or damage , she idles fine with no smoke , the egr valve is good , anyone any ideas thanks
P0299 is a turbo boost problem, maybe the waste gate is stuck or a pipe is loose?
could be turbo vacuum boost solenoid valve??????
Last Post: ADarkDividedGem
Yesterday 08:06 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
