[Engine] Which 1.6HDi has a DPF?
I'm currently looking to buy a 1.6HDi and wondered when they started to fit DPFs? The one I'm looking at is M59 2007. It's actually a Pug Partner.
(11-07-2018, 01:44 PM)cancunia Wrote:  I'm currently looking to buy a 1.6HDi and wondered when they started to fit DPFs? The one I'm looking at is M59 2007. It's actually a Pug Partner.
Mine is 2007 (September), 1.6HDi, 9HXC engine, M59, Partner Escapade (metal grilles on the headlights). There is no DPF.
Cheers,
saskak
I had a 2008 M59 van with the 1.6hdi and it had a dpf.
Take a look at post # 2  at the link-
https://www.berlingoforum.com/thread-170...#pid109715
  • cancunia
Thanks JJ9, I'd forgotten about your post.
I also found this on here:
https://www.berlingoforum.com/thread-101...ht=1.6+hdi
I've asked the seller for the VIN, or at least the relevant part of it, but no reply just yet. Not so long ago you could get the VIN from the Registration Number fairly easily but all the links I tried did not work.
There's nothing on my pillar data plate stating HP that I can see, just tyres sizes & pressures.
I take it it's a multispace your looking at?
I've never seen a M59 multispace with a DPF, but that's not say they don't exist.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
