Hi all,
My turbo/exhaust heat shield has broken off from one of the bolts and is vibrating with some horrible sound. I suspect this is a relatively common fault and it would be great if someone can provide some pointers on how to replace it. I have currently secured the heat shield with heat-resistant steel ties, but from vibrations they brake off every 1-2 months, so I want to replace the rear heat shield (engine-side).
This is for the M59 (2007 1.6HDi, no DPF). As per another thread, I think both parts of the heat shield can be taken out upwards with some wiggling. This will be the easiest option, if possible, as I would not need to remove the exhaust. Here is how it has broken off:
rear_heat_shield_broken.pdf (Size: 6.36 MB / Downloads: 29)
I am a bit uncertain about several points.
Does anything go through the hole in the middle of the rear part (engine-side) of the heat shield (pdf with arrow pointing to the hole)?
I think that the banjo bolt with the oil pipe go around the heat shield, so if I am careful taking it out it should not affect the turbo oil pipe?
My main concern is the two bolts and bracket (number 3 in pdf) that hold the cat/exhaust in place. In order to take the heat shield out I need to undo the two bolts, so the cat/exhaust will be held in place only by the turbo and the rear part of the exhaust. Will this be enough not to drop?
M59_heat_shield.pdf (Size: 191.11 KB / Downloads: 26)
Any other pointers are more than appreciated. Thanks.
Cheers,
saskak
Cheers,
saskak
