ABS
Afternoon, does any member know what ABS code 5331 undefined relates to please....
Thanks in advance?
may be abs speed sensor fault......
A quick internet search shows this to be a Right Front Wheel sensor - this was on a Peugeot 207 so probably applies to a Berlingo. Have a search around - you should find more info.
Regards.
(19-07-2018, 09:43 PM)Boxer Wrote:  A quick internet search shows this to be a Right Front Wheel sensor - this was on a Peugeot 207 so probably applies to a Berlingo. Have a search around - you should find more info.
Regards.
Morning, yes I initially went for the right hand front speed sensor, but after changing ABS light still came on after driving so swapped it over with left hand front and still same. Tried google search but can’t pin point this error code. Suppose it’s going to have to go to main dealer  Angry
may be the magnetic part on wheel hub needs cleaning........if its gumbed up,won't be making magnet field to sensor
(20-07-2018, 10:10 AM)gazthelad Wrote:  may be the magnetic part on wheel hub needs cleaning........if its gumbed up,won't be making magnet field to sensor
Yep thought that as well tried brake cleaning on the mag abductor rings to no avail, really hoping it’s not the ecu on the pump but think it may be .....
clear all error codes in lexia........then see if fault comes back......
If you have replaced the sensor, and the air gap is good between the sensor & pick up , you may have a wiring fault.
We have had several C4 Picasso’s with this issue on the 0/s/f.
It will take some fixing, dealers will not come up with a solution you will like.
Maybe a new harness Angry
The best fix is to get access to the abs computer (n/s/f wheelarch) find out which wires go to the offending sensor & check for continuity.
If one wire has failed, they are twisted pairs, and often corrode together. The best remedy (cost Effective) is to run two new wires to the sensor.
Give me a call if you need help.
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
