Hello, I have a 2008 berlingo 1.6 hdi (9HW) which wont start and as I was reading this problem it seems it's a common problem
the battery is ok, fuses are ok so im guessing the starter motor finally died since i had some problems with engine turning over before usualy in winter.
I removed the air filter and i encountered endless cables and hoses and here is my question since im not a car mechanic and im not too familiar with the anatomy of a car engine, do i need to drain something before uncoupling hoses since im not sure where and if there is any fluid in them.
I read the haynes manual for 2005 berlingo but there it just says on page 221 of pdf to unscrew the thre bolts and remove the starter motor, but on this model acces from below seems impossible
Edit:
[img]SM https://imgur.com/gallery/P4DDmIy[/img]
the battery is ok, fuses are ok so im guessing the starter motor finally died since i had some problems with engine turning over before usualy in winter. I removed the air filter and i encountered endless cables and hoses and here is my question since im not a car mechanic and im not too familiar with the anatomy of a car engine, do i need to drain something before uncoupling hoses since im not sure where and if there is any fluid in them.
Edit:
