  • 14 Vote(s) - 2.21 Average
2001 600D - Draining the coolant
Hi guys, I need to replace the coolant and was wondering how to drain the radiator? I can't see any drain plugs and the only bottom hose on the rad is inaccessible without taking the rad off :/
I've got a Haynes manual and that suggests removing the cylinder
block drain plug
so if anyone can point me to a pic of that I'll be so grateful.
Thanks,
Lou
Hi Lou.
Remove bottom hose and drain coolant.
But, be very careful!
I have had a look at my 2004 model and there is no drain point.
The bottom hose is the only way to drop it out.
Hi, Just done it on an 02 1.4 Multispace. I found it easier by taking the plastic wheel arch liner out. Not sure if yours is the same. The bottom hose goes behind it at first. It will certainly help to get the hose back in. I also unbolted and moved the washer bottle. I did need to use a header tank, as suggested in the Haynes manual, to refill.
Regards,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Thanks guys.
I want to flush the whole coolant through the engine as well.. by taking off the lower pipe from the radiator how will I get the clean water going through? Or should I just drain, fill, drain, fill with coolant?
Lou
(22-11-2011, 01:23 PM)BLINGONOOB Wrote:  Thanks guys.
Lou
hi I need to do the same on my 2001 1.9D did you find out how to do it or can anyone else give some advice.
thanks
Today 08:07 AM
» Replies: 28
Unusual Braking Problem
Today 07:52 AM
valeo alternator CL15 rebuild
Today 07:49 AM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:08 AM
Insurance Shocker !!!
14-03-2025 09:04 AM
13-03-2025 08:09 PM
