Threads: 44
Thanks Received: 11 in 10 posts
Thanks Given: 19
I use my Berlingo in micro camping mode for hiking and do not always drive again before the next days walk so I wondered about depleting the leisure battery.
The leisure battery is fitted in the boot area of my Berlingo; it was professionally fitted. I use a cigarette lighter extension lead from it which it more convenient to use to fuel my small kettle or recharge my phone. If I remove these items from the extension cable but do not remove the cable from the battery i.e the red light is still showing is fuel still being taken from the battery? To unplug the cable easily means inconveniently going outside and into the boot. I am thinking not, I guess a bit for the red light, but someone with more electrical knowledge than me (not difficult) would have the definitive answer.
Threads: 20
Thanks Given: 7
14
Fit an isolator switch on the live cable
Threads: 20
Thanks Given: 7
14
https://www.furneauxriddall.com/cgi-bin/...l#SID=1009 one like this - this is how we isolate batteries on a boat
Threads: 7
Thanks Received: 209 in 121 posts
Thanks Given: 16
9
Question is - Where do you locate the isolator switch?
If it's fitted close to the battery, which is best practice, then you still have to go to the boot to turn it off.
Gravity
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
I'd just suggest checking the leisure battery voltage for a couple of nights ideally when you are at home. 2 or 3 with the gubbins connected then 2 or 3 with the negative terminal removed. That should give you an idea of how much the voltage drop is across a normal evening and then the difference with just the battery sitting by itself.
A leisure battery is designed to recover from a deep discharge and I would have thought that a single LED is not going to kill it overnight. We run a 110 Ah one in our caravan and there are a couple of permanently wired 'thingies' in there with LED display (including a handy voltmeter) and over an entire weekend we see no appreciable voltage drop.
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
Threads: 44
Thanks Given: 19
Thank you for the information.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Is that, a 12V extension lead with a built-in LED?
Unless there's some really weird electronics in there, I'd expect it to draw 20 - 50mA.
This means it would take 20 - 50 hours to drain 1AH off of the battery.
Even at the horrid rate of 100mA, it would take a MONTH to deplete a typical 60AH leisure battery that's fully charged.
Threads: 7
Thanks Given: 16
9
02-08-2018, 10:44 AM
(This post was last modified: 02-08-2018, 10:52 AM by Gravity.)
If it's wired with the correct type of relay (see my Camper thread) it will be connected in parallel with the normal starter battery but will not be used by the car electrical systems - ie. it will not assist the car battery when you start the engine, for instance.
The alternator will charge both batteries as needed while you are driving, so - unless you have had a big drain (and a cooler is a big drain) - the leisure battery will just get a trickle charge.
So the only drain on the leisure battery would be the leisure items that you use while you are stationary with the engine off, such as additional lighting, cooler or frig, plus any leisure sockets for moblle, tablet, tv, etc.
It shouldn't take much driving to keep it topped up, but even if it's drained heavily to within an inch of it's life, it should recover easily - being a deep cycle unit.
As for a red led light showing, just ignore it. I often leave my cars unused for weeks with a couple of led light blinking (alarm etc) with no ill effects.
Gravity
The following 1 user says Thank You to Gravity for this post:1 user says Thank You to Gravity for this post
• dumdum
Threads: 0
In my opinion I would take the car to a professional workshop.
