Threads: 2
just put my multispace 2004 through the mot,it failed on an airbag light
so tried a few of the usual checks wiring under seats etc but no joy
so asked a mechanic friend and he told me that if it doesent light up it cant fail
so covered up the bulb,back in for mot and it passed as an advisory.
Threads: 9
Thanks Given: 316
15
Hi and welcome to the forum and thanks for the heads up - unsure what you men covered up the bulb?
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
(29-07-2018, 04:41 PM)Brittz5 Wrote: (29-07-2018, 04:25 PM)polar Wrote: Hi and welcome to the forum and thanks for the heads up - unsure what you men covered up the bulb?
HI i removed the console cover, undo one screw
remove glass from das Drh, the lights on dash circuit board
are fixed so covered the hole that it shines through.
I thought they had to check the light came on as a check when ignition switched on, then switched off when the engine was running. Pretty obvious if you have airbags.
I dont think I would be covering an airbag fault light. I think I would be find out what is wrong with it.
Malcolm.
2001 1.9D Multispace.
Threads: 7
Thanks Received: 210 in 121 posts
Thanks Given: 16
9
That's called hiding the symptoms without fixing the fault.
The Mot test is there for a purpose.
It helps keep all road users safe.
Cheating instead of accepting that there is a fault and getting it fixed goes against the reason for the test.
Gravity
Threads: 29
Thanks Given: 67
20
Whenever mine does it it's the connector under the driver seat, I unplug it and give it a squirt of cleaner then put it back together and it works properly.
Threads: 22
Thanks Given: 8
When mine came on diagnostics said drivers side. Did all the usual stuff without success. Was ready for MOt failure next year, the suddenly thought, drivers side! French!. Put my hand under passenger seat, found socket, CLICK!!! No more air bag warning light.
Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
Try soldering the cable connections under the seat = no more worries..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
