Hi All,
I have a 2010 Multispace with roof rails (run front to back), are there any cross bars I can get to fit these should I need to pick up some timber or alike that wont fit inside?
What do you recommend?
Cheers,
Paul.
Mine looks the same as yours and mine turn
Have a look at the plastic ends you should see a part that 'tips' up
In your toolkit there should be a L shaped tool that releases the bolts
M49 and M59 models can turn their bars, depending if Modutop or not - but B9 models won't turn. Looking, you can see that they're too long to go crossways.
