[Steering & Suspension] spring sizes....
I know this is a stupid question even as I type it.........
Are the front springs different diameters???  I had a broken spring replaced recently. Yesterday I heard a familiar "crack". I had a look and I dont see anything broken, however, springs look different left and right......
Thanks !
Do you mean different wire diameters ? They can be from different manufacturers, the wire diameter and number of turns can differ to make up the poundage.
I was more thinking about overall diameter.....
Its not best practice to just change one spring on an axle especially if they have both been on for years.
If the wrong diameter spring was fitted it would not fit properly in the spring seat at the  bottom of the spring. Feeling with your fingers would show if any difference. Unless , the strut was also changed for the wrong one. (second hand one ?)
  Measuring the diameter of each side would show if they are wrong.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Wee update, I had a broken spring.....broken right at the top....
As Tomcat ... always fit springs in pairs on the same axle.
Springs fatigue in use, so the new spring will take more punishment than it would if two were fitted.
And beware the winter months!
Mix cold weather, short journeys and speed bumps and you have a recipe for broken springs!
Gravity
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
