Lexia diagnostics fault
Hi all a little help please have run lexia and diagbox it reads the injection module codes and ABS but says no to every other module i have used pp2000 fine on my old partner but first time with lexia BTW reason for diagnostics is airbag no light on dash but centre display says passenger airbag disabled airbag fault connected maybe?
Desire 1.6hdi 07
Or is it disabled because the previous owner used a baby seat in the front?
If so, you can simply switch it back on again.
Just thought ....
Gravity
[-] The following 1 user says Thank You to Gravity for this post:
  • Mankee
(02-08-2018, 09:16 PM)RoyalBB Wrote:  Hi all a little help please have run lexia and diagbox it reads the injection module codes and ABS but says no to every other module i have used pp2000 fine on my old partner but first time with lexia BTW reason for diagnostics is airbag no light on dash but centre display says passenger airbag disabled airbag fault connected maybe?
Desire 1.6hdi 07
Some modules are connected over other modules. eg. radio is connected over dash. If you unplug
dash lexia can't connect to radio. I don't know how airbag module is connected. You can check
wires on airbag module. Communication wires are always twisted. Follow them and see where they
connect to.
Also you can use pp2000 on your Berlingo and vice versa
best regards,
brajomobil
Thanks for replying I have opened a can of worms I found a power cable solded to a connection that went to bsi disconnected it and airbag warning light on dash never came on followed it to a box which I think is a timed device to make it look like airbag light lights up and goes out to fool mot then disabled diagnostic port somewhere so cannot get codes am well p#*** off.
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
